Cold Air Intake
Gman1950
Car: G35 and QX4
I just had an Infiniti dealership install a Stillen Cold Air Intake on my 2004 G35, and it ran fine for a day or two and now it has a hard time holding the RPM's in idle. It drops to around 500 and jumps to 1100 and back down.
Thoughts?
Thanks
smockers83
Car: 2006 G35 Coupe
Well, since the dealership installed it, they would have known to be careful with the MAF sensor, I would hope. Try disconnecting the negative terminal on the battery (the black one) and then pump the brake pedal a few times. This should drain power out of the ECU and reset it. Reconnect the terminal and take her for a spirited run and see if that fixes it. If it doesn't, go back to the dealership and let them deal with it. They installed it so they can't deny you warranty work if need be. Even if they try to deny you warranty work, they must be able to prove that the intake caused the problem, which it shouldn't have.
G_whizz
Car: 2010 G37 Coupe Sport
smockers83 wrote:Well, since the dealership installed it, they would have known to be careful with the MAF sensor, I would hope. Try disconnecting the negative terminal on the battery (the black one) and then pump the brake pedal a few times. This should drain power out of the ECU and reset it. Reconnect the terminal and take her for a spirited run and see if that fixes it. If it doesn't, go back to the dealership and let them deal with it. They installed it so they can't deny you warranty work if need be. Even if they try to deny you warranty work, they must be able to prove that the intake caused the problem, which it shouldn't have.
Solid advice x 1000
And welcome to NICO!
aukword1
Car: 04' g35, 04' rx8
reset the ECU...that should fix it..
joe603
Car: 2014 Durango R/T
I would also try to reset the IAC...
Follow the reset procedures from the G-Series FAQ page (see my sig)
Welcome to NICO BTW!!
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
Can add anything more here except..
Welcome to Nico!
Gman1950
Car: G35 and QX4
Good Afternoon:
Thanks to all for taking time to help me out.
A Great Forum.
GMAN1950 AKA: 24KTZ
snwbrdr435
Car: 85 VW Westfalia, CBR F4i, SV650s, 1988 Honda Hawk(race)
Welcome to Nico!
