Wich is called Hydro lock.BlakDrag0n9 wrote:Also with long intake, there is a possibility of sucking water into ur engine!
.........why in the hell would you drive your car into deep water? The cold air intakes won't ever take in nearly enough water for hydro lock.BlakDrag0n9 wrote:Also with long intake, there is a possibility of sucking water into ur engine if u drive in deep water or in puddles!
Your source please?redtop91 wrote: intakes won't ever take in nearly enough water for hydro lock.
http://www.aempower.com/Faqs.aspx?CategoryID=20AEM wrote:Q: When should I use an Air Bypass Valve?
A: The AEM Bypass Valve protects the engine from ingesting water and hydro-locking if the filter becomes submerged in water. Hydro locking occurs when the end of the inlet pipe is submerged in water and the water is sucked into the engine. Driving the vehicle in rainy conditions is not enough to cause a problem unless the vehicle submerges enough that the inlet end of the pipe is immersed in water. Rain impingement on the filter will not cause a hydro lock condition.
The distance of the filter from the road dictates the level of water that can cause damage. This distance varies with the vehicle ride height, which is why there are no published numbers for this measurement. We suggest taking this measurement and keeping it in a log book, so that in the event you encounter deep water you will know what your maximum allowable depth is before potential submersion of the inlet pipe.
All AEM Cold Air Intake installations retain the factory splash shield (fender liner) for filter protection and performance. Removal of splash shield actually deteriorates performance by allowing air heated by the pavement to enter the filter and negates any positive pressure created in the air filter area when the vehicle is in motion.
There are some instances where there is not enough room around the inlet pipe for adequate clearance of an Air Bypass Valve. In these instances, we recommend installing a Short Ram system if water ingestion is a concern.
Yeah same on, just mine is 50 cents cheaper, lol, it's all about bargaining baby!
Go short ram. No doubt about it.biggee247 wrote:Okay so pretty much short ram is the way to go. Judging by research long ram is better because it get's colder air rushed into it, but it really wouldnt make a big difference.
I believe ill go short ram.
What is the best intake to buy w/filter. Im looking for short ram air, w/great filter. Cost isnt an option at the moment? Like a reputable dealer online.
amen brother. e-bay piping, just buy a high flow filter. saving money ftw.240FeVeR wrote:I never understood how come these intakes are so expensive. If you guys took some initiative you could have made your own for less than $40. I bought two intakes from ebay (for different cars) and did a little cutting and fitting ..had a cold air intake for less than $25. ;x
