Cold Air Intake
Shahee1
Car: 1993 240sx w RB20DET
I have a 93 240sx and I am trying to replace the air intake with a OBX style cold air intake. The stock intake has 3 vacuum hoses attached to the factory intake tube. The OBX has only 2 ... what is a solution for the vacuum hoses??? OH ... dont let me forget the hose that is attached to the air box ... so that makes four ...
silvia240sx
Car: SPEEDING
hey if its the 1 that runs on the backside of the box its still a vacum it still sucks air in so i put a breather filter on it if its anything elese plgu it with a rubber stopper
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
Hes referring to the little black box (AIV). Its ok to put a breather on it.
Nismo1182
Car: Z06
nnkfws333 wrote:Hes referring to the little black box (AIV). Its ok to put a breather on it.
I went a head and removed mine ;) Didnt throw any codes or anything. Just get like a drain plug at Home Depot to screw into the whole left at the header.
midwestdrifter
isnt that just for emissions? i assume your car still runs ok. tell me more about this....plug.
Shahee1
Well that kills one of the lines ... how about the other line that is left over??? The OBX air intake has two fittings and the factory intake has three???
95_240sx
Car: My baby (car)
One should be a PCV, you can put a breather on that too, if not, get some 'T's' for hoses and do it that way.
Rick
singlecamhonduhkilla
Car: learning all i can about this car.. some street racing.. etc..
I ALWAYS WONDERED THAT TOO.. I SAW A CHEAPO INTAKE FOR MY KA24E ENGINE.. BUT IT DOESNT HAVE ANYTHING FOR THE TWO VACUMM LINES ON THE LEFT SIDE OF THE PIPING.. COULD I JUST MAKE SOME HOLES IN THE PIPE OR WHAT?JOE
S-14boy
Car: 1998 Nissan 240SX SE
Ummmm...are you sure its ok to put breather on your PCV, I did that on my Honda I used to have and blew out the oil pan gasket.
midwestdrifter
yeah you can put a breather on it. there isnt even a valve in mine. just a little pipe cleaner looking thing. really you dont have to put anything on it, but a catch can is cool.you probably blew the gasket because the breather got cloged or it just had too much resistance to start with.
Shahee1
I gave up and I am now looking to get an INJEN intake ... never buy an intake from EBAY ever again ...
I emailed the seller and he emails back saying that he has a set of AEM instructions that might help ... I ask myself whay do I need AEM instructions for an OBX intake???
Stay away from ebay intakes ... I took the intake to a welder and he said that just by looking the intake would not work and it would cost me 50 to 60 for adjustments. Since then I have went looking for T-Valves and none fit or if they did then they were too small for the hoses. It is hopeless ... I have to take a loss on this.
