IronAnaconda wrote:i just wanted the bypass for ease of mind but thx a lot for the info
Nothing wrong with extra insurance. If you must get one, you should only need one that is the same size as your intake pipe. They use a flap that opens when there is too much vacuum so during normal operation it should not allow air through it. To be safe though, install it before the MAF and at a higher level than the filter (highest point is best).
I can't say much about the ebay model. The AEM one works. AEM displayed one on a long tube attached to an NSK which they submerged the entire filter in the water. The water came up to some extent but never passed the bypass. It was however, disconcerting how high it came up the tube. Though, I think it was running a higher throttle application. I doubt most people will run such high throttle inputs while submerging their car that far into water.
