LongBeachCoupe wrote:Lizard... DO NOT LISTEN TO THEM..ALSO GUYS DONT POST INFO IF YOU ARENT SURE, IT MISLEADS MEMBERS!
The only thing it voids is the warranty on your air intake....The mossberg act protects you in this...
If your Injen falls off and you suck leaves into the engine, thats a different story.. But if your alternator breaks or your headlights dont work etc its still covered...
THEY HAVE TO PROVE THAT THE AFTERMARKET PART caused the failure, so the only thing that you are voiding is the intake warranty... although you can always switch it back.
dont listen to what? i said if it does void the warranty, before taking it back to the dealer re-install the stock one."although you can always switch it back."im pretty sure that is you repeating the same thing... so what wouldnt he listen to?
