Mark Sheriff wrote:or you can build your own for about $30 like i have:
Thanks for posting the model number, I just bought oneatraudes wrote:I installed the K&N 57-6011 in my 2001 QX4 with no problems. Officially, it was only supposed to fit the 01 Pathfinder, but I didn't have any problems. The only complication was that the filter was a bit of a tight fit, presumably due to the HID headlights. Dunno if the fit in Pathfinders was any different, though.
The 57-6011 is supposed to fit a 2003 Pathfinder as well, so I'd say give it a go.
How do you keep the Hot air being recirculated from the engine into the cold air intake when the hood is closed?Mark Sheriff wrote:you can choose your piping from: http://intakehoses.com/Merchant2/mercha ... y_Code=ITN
click on straight intake tubing and i think it was the 7" tube i got, the link for the straight intake tubing is down right now for some reason but you can get any pipe like that and i believe this pipe is 3.5" diameter
then you can buy the air filter cone on ebay and the maf sensor adapter also on ebay,
the vacuum lines were also purchased on ebay, i forgot what size they were but you can measure the stock tubing you took off and get the diameter.
you will then find two barbs that fit the tubing (found my barbs at lowes) and then drill the metal intake tube to fit the barb. then you seal the connection with jb weld(which held up pretty strong)
lastly i painted the intake tube black and connected everything.
the post for the build is here and in this thread the lines were red, but i changed it all to black:
post6534420.html#p6534420
Let us know how everything went !ILLuSioNzX wrote:Thanks for posting the model number, I just bought oneatraudes wrote:I installed the K&N 57-6011 in my 2001 QX4 with no problems. Officially, it was only supposed to fit the 01 Pathfinder, but I didn't have any problems. The only complication was that the filter was a bit of a tight fit, presumably due to the HID headlights. Dunno if the fit in Pathfinders was any different, though.
He doesn't. I view these as more of a hot air intake. The stock setup at least pulls air from inside the fender, this kind of setup usually has a negative effect.greengumby wrote: How do you keep the Hot air being recirculated from the engine into the cold air intake when the hood is closed?
patqx4 wrote:He doesn't. I view these as more of a hot air intake. The stock setup at least pulls air from inside the fender, this kind of setup usually has a negative effect.greengumby wrote: How do you keep the Hot air being recirculated from the engine into the cold air intake when the hood is closed?
If you really want fresh outside air for your intake, as opposed to a warm-air-from-under-the-hood intake, then that is what you need to do: Cut open, or remove, the resonator in the fender well, and remove the black air box.Mark Sheriff wrote:I've been looking for a way to have a shield on there to block engine heat, i know when I'm driving its okay cause air comes through the front by the radiators and up into the engine bay also, i traced how my stock air box was and that too pulled air from my engine bay and not my fender, pulling out the air resonator from under the fender is how i found that out
-cold air also come in through my fog light vent and up into the hole that's right under the air filter
