Cold air in take for the M37X
Ray49
Car: Infiniti M37X
I’m looking into installing a cold air in take into my 2013 M37X but I’m having trouble finding one that is compatible. There is one from K&N 69-7078TS says it fits the G37. Will that work on the M37. If you’ve installed a cold air intake what system did you go with and what are your thoughts?
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
I bought an R2C off of a member on a G37 enthusiast's site.
You can see what it looks like here: what-did-you-do-to-your-m37-m56-q70-tod ... 85-90.html
Honestly, I don't think it made much of a performance difference, but they look real nice, especially if you get the black hex filters PLUS
(I had the black nickel finish) and I think the intake sound is louder.
Ray49
Car: Infiniti M37X
That does look nice I dig the black nickel finish. I figured it wouldn’t do much for performance but I do like the sound and looks of it. And the R2C was able to accommodate all the hoses on the left side? Thank you I appreciate the response and the pics.
pedsemdoc
R2C Intakes
Oil catch cans
Ray49 wrote:
Thu Aug 20, 2020 4:59 am
There is plenty of room on both sides - took a little wiggling and adjustment to make them sit just right and look symmetric (since people are always looking at your engine bay, right - lol. I did not use the brackets that come with the heat shields because they are stable enough without them and felt like I didn't need to clutter the engine bay.
Some users on the G37 site said the black nickel was hard to maintain - seemed to smudge too easily. I didn't have that problem. I just wiped them occasionally with a microfiber towel and they were good to go.
Shanehsmp
Car: 2006 Infiniti M35x - Sold
2012 Infiniti M56x
2016 Infiniti QX70s
Get a pair of long tube intakes that install through the radiator support (370z or G37). There's a thread in this forum with a member installing his. You will need to drill ~3" holes in the housing to fit, but it's worth it imho (with a tune afterwards).
wideopn11
Car: 2012 Infiniti M37x Moonlight White
Takeda CAI
Stillen exhaust w/ MeganRacing Y-pipe
SCALE coilovers 16K/10K F/R
Akebono BBK
Cusco strutbar
25mm spacers F/R
Uprev tune by seymore4
Don't do K&N on these motors.
I run Takeda. I think most g37, 370z intakes will fit...some better than others.
attila
Car: 2012 M37X
AEM sold a kit specifically for the M37..
https://www.aemintakes.com/cold-air-int ... finiti/m37
airmanhoward
Car: 12 M37-Current
08 civic lx sold
06 M35x Totaled
2000 S10 sold
Ford contour svt-sold
91 caprice-sold
90 & 93 maxima-sold
96 ford escort-sold
I would like to hear the AEM one in action.
cliffyk
Car: 2012 Infiniti M37 Premium Pkg
The stock intakes are "Cold" (actually "Cooler" air as there is no such thing as "cold" air) Air Intakes, and ones that were specifically tuned for the engine by engineers with access to air flow and engine performance instrumentation K&N and others can only dream about. Airflow is where volumetric efficiency comes from, which is where lowered emissions and maximum power and effective use of fuel (to brag about in ads) come from.
In this age a manufacturer would have to be just plain stupid to not install the best tuned, best flowing intake they could muster.
Intake air flow on a piston engine is not a constant draw, but rather a series of pulses each having a lower than ambient air pressure head, a near ambient pressure body, and a higher than ambient pressure tail. This is just the opposite of exhaust pulses; but like exhaust pulses they occur at varying frequencies proportional to engine speed. A properly tuned intake is designed to eliminate/minimize any harmonic stagnations brought about by harmonic resonances within the intake path. Intake tuning is at least just as important as exhaust tuning, and arguably more important.
Not a day passes that I do not hear some "fast & furious" wanna-be rice-mobile with an aftermarket CIA that on hard acceleration in mid-range rpm just makes a muted breathy "WAAAAHHHH..." sound as the engine struggles for air and the car struggles to do 20-45 in something under 8 seconds.
Shanehsmp
2012 Infiniti M56x
2016 Infiniti QX70s
cliffyk wrote:
Fri Sep 04, 2020 6:46 pm
There's always one.
Intakes mounted in front of the radiator have been documented to provide HP gains when properly tuned.
I wish people would stop with the "the engineers at ______ designed this thing to perform as so and so and such and such..." just because it's enginered, doesn't mean it's engineered to provide the best possible outcome/performance.
Ilya
Shanehsmp wrote:
Fri Sep 04, 2020 7:22 pm
There's always one.
You may disagree with how he posted his comment, but he's not wrong on this platform. The intake on the Y51 M is very likely as good as you are going to get. Unlike many intakes that pipe down towards the ground and as a result have a ton of tubing heat soaking, the OEM intake is above the radiator and is sucking in truly fresh air that hasn't been pre-heated by even 1*.
cliffyk
With the polymer tubing used in most contemporary intakes, heat tranfer to the incoming air is minimal. Even at idle as the velocity of the intake air is sufficiently high (45 to 50 cfm for the 3.7 L) that any heat transfer from the tubing to the moving air mass will be very slight--by 2000 rpm (128 cfm) tubing tubing to intake air heat transfer is negligible. This is also true, but not as true, of metal intake tubing. However adding the generally poor heat transfer/absorption characteristics of the plastic tube into the overall scheme further reduces heat transfer to the intake air to nearly trivial.
With plastic tubing heat soak of the intake tubing/etc. could induce measurable effect on intake air temps at start up and just after coming away from an extended idle, however beyond that it's effect is inconsequential as the dwell time of the intake air mass within in the tube is so brief...
