rxm6 »
https://forums.nicoclub.com/rxm6-u60513.html
Sun Sep 23, 2007 7:20 pm
For the past month or so I've been watching my gas mileage consistently stay below 20mpg and my performance slowly get worse as the car heats up. I finally decided to do something about it.
I was fairly certain it had something to do with my intake due to the fact that A) at 6:30 in the morning right when I start up my car and accelerate down the street, the performance was pleasing B) as the car warmed up that pleasing feeling went away, and C) My gas mileage was pretty bad.
Here is my original setup that Cosmo racing sold me:
Removal of the stock intake system really opens up the compartment and lets a lot of air swirl around in there. The problem with that is that all that air is coming right through the radiator and into your intake. A log of the air intake temp sensor revealed that 132F air was being sucked into the engine at standing idle!! So with my trusty laptop logging software booted up and ready to go, I set off to create a colder SRI.
**By the way, all these tests were performed at approximately 63F at sea level.**
As I said before, standing idle showed intake temperatures at 132F. At a steady speed of 45mph the intake temp dropped to 108.9F. And after a standing idle of 20 seconds, the intake rose to 115F. Not good.
I've seen a lot of guys on here take off the top of their air intake box and stick a filter there. So I tried this with my Cosmo:
Tests showed a 10F decrease in standing idle temp to 122F. Also a small decrease in the steady 45mph test to 105F. Still poor, but getting better.
I noticed in doing these tests and trying to figure out how to make my intake better that the metal tubing of the intake was getting extremely hot because the radiator fan was blowing air directly on it. So I wrapped it in heat wrap. Also, I noticed that most of the heat was coming from over the top of the battery and resulting in such a hot air intake temp. I was determined to get my SRI cooler.
The 3rd evolution of my design yielded the greatest gains and is what sits in my car now. In approximately 63F weather at a steady 45 mph I was recording air intake temperatures of 68F! Also, I've noted a substantial difference in the power of the car, however, I have no data to back me up on that. One other interesting thing that I noted was that at 45 mph with cooler air, the rpms dropped from 1600 to 1550. Not sure that makes to much of a difference, but something worth noting. Here are pictures of my final setup:
Modified by rxm6 at 10:33 PM 9/23/2007
