Coilpack Wiring ('91 Q45)
Raxephon
Car: '04 RX8...for the moment...
1991 Infiniti Q45Base Model (But still nice for a "Base" model )
What is the purpose of the 2 wires that run to the release button on the coilpack connector? (At the coil of course)
(Not the 3 main wires inside the connector)
I checked the ECCS Wiring diagram in my '91 FSM and elwesso's '94 FSM, and they are not listed with the injectors in either.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I noticed those as well... im not sure what theyre for.... not sure anyone has ever asked. maybe its like an extra ground or something.
Raxephon
Well I traced the wires back to the 2 pin connector that sits on the ignitor.
On my Q45 those particular plugs are not connected to anything, so I'm just going to completely eliminate them from the harness.
(Photo borrowed from http://www.q45.org for illustrative purposes only.)
Theoretically its for some kind of diagnostics tool?
Raxephon
Wes- I don't think its an extra ground since it doesn't connect to the ground wires at all.
Jesda- Maybe. But what would it test? To see if the harness is still connected to the coilpacks?
Any ideas as to why the odd cylinder coilpack harness has an inline resistor and the even cyl. harness doesn't?
(Gray ,rectangular shaped casing. Has a "2.2K Ohm/omega , 9Y20 written on the end of it.)
Modified by anlasak at 4:03 PM 10/9/2005
