Coilpack voltage question(s)
Raxephon
Car: '04 RX8...for the moment...
FSM states that the ignition signal is:
70mV @ Idle0.14V @ 2000 rpm
What can I expect if it was:0.2V @ Idle0.5V @ 2000 rpm
What problems can I expect to occur? Will it fry the coilpacks? Will it fry the ecu? Will it cause error codes or gremlins?
Any input would be appreciated.
Raxephon
*Bump* Anybody have any insight into this?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Where are you taking this measurement... at the ECU I presume?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
I think the coil pack is a passive device so you would just get more voltage at spark gap. Maybe Dennis will chime in as he is the BSEE.
Modified by maxnix at 10:09 PM 9/12/2006
Raxephon
elwesso wrote:Where are you taking this measurement... at the ECU I presume?
Yes, @ the ECU.
Q45tech
The ecu provides a shift in base voltage to the switching transistor for each coil.................zero > to something positive............the coil fires when the primary current collapses base goes to zero. Mismatching the transistor with a different coil [different primary resistance] can exceed transistors capacity.
http://www.asashop.org/autoinc/feb2003/ ... ct...shtml
http://www.picotech.com/auto/w....html
