coilovers, yea i know....but what else???
TK_Encore
Car: 1990 240sx
ok so i have cut springs at the moment(not my doing ) but im planning on going with coilovers later. but what else should i look to replace or fix that might be damaged from the bad suspention as it is now???
ThuG LyFe
Car: 95 S14
well it's always good to have adjustable arms and rods and bushings replaced at the same time. it'll also help your car get back to the factory settings when you get an alignment if you drop your car.
TK_Encore
Car: 1990 240sx
so i should buy these new when i change to coils?
ThuG LyFe
Car: 95 S14
well when you get coils and lower your car the suspension geometry changes like camber toe caster etc. if you are looking to go all out then get adjustable arms so you can adjust the specs back to factory specs.
if i were you i'd just start with a set of like megan street coils and a megan RUCA for the camber in the back. that's all i'm running and i'm pretty content with how my car runs.
TK_Encore
Car: 1990 240sx
that sounds good. but i was just wondering if since im driving with the cut springs right now is there anything i should be aware of that should be replaced later as in it went bad from the bad ride quality of the car now
bee_afraid
Car: 93' EG hatch
TK_Encore wrote:that sounds good. but i was just wondering if since im driving with the cut springs right now is there anything i should be aware of that should be replaced later as in it went bad from the bad ride quality of the car now
Only the bushings and your tires that you probably go through left and right.
Gabes13
Car: rb20det s13
i'd say some tie rods the bare minimum.
TK_Encore
Car: 1990 240sx
alright thats whats what i thought, thanks all
