Ssexton wrote:I know that coilovers are usually always the correct answer but they are very expensive. I have enough to buy the K Sport coilovers atm. All i really want is the drop. Lower the car just a couple inches to give it a better look imo. Ive heard alot of mixed things on lowering springs. Are springs really that bouncy? Is the ride quality worse than OEM? If there is a good quality set of springs for the M35 I'd like to know before I spend $1,000. If anyone has any experience with springs and coils for the M please let me know how everything went.
This topic has been discussed many times.
It all comes down to preference and what you are trying to achieve, also if you are going with after market wheels.
For me, I was in your shoes, I just wanted the drop because I was happy with the sport 19"inch wheels, so I went with springs and new shocks/struts. It ended up costing less than coil overs. I choose Tien S Tech springs because they provided the most drop out of all the springs which I do scrape from time to time and very hapy with them, no bounce. Most members on here are using Eibachs Pro Kit.
Well I ended up bending a rim and needed new tires so I pulled the trigger on set of 20" wheels and this where I kinda regret not get coil over, now I want airbags and i could of done it with the coils over bags.
Like I said man, all depends on looks/stance, ajustibilty and wheels. Some other member just installed K sport, maybe he'll chime in or look up his post.
