NISMO_RB25 »
https://forums.nicoclub.com/nismo-rb25-u11080.html
Fri Jan 14, 2005 4:02 pm
This all very much depends on what you want to do. I have the tein flex coilovers and they are great, as long as you don't have a long dirt drive way with potholes (which I do) On the street or track they are the bomb and the height adjustment is great.
Now if you have a pot hole filled driveway and plan to drive in and out of it every day then I would recommend a softer spring rate. Most all the drift suspension is going to be worse.
I don't remembe what my spring rates are, but you should be able to find that out pretty easy, and so if you want a softer ride you can get something softer than mine.
Good luck to you!
