Yeah, and are those 17s or 18s?fourLUG_hero wrote:You got JIC's? My sig picture is maxed with one collar removed.
To go any farther, you either need to get shorter front springs or Powered By Max coils.Future_gohan wrote:
Okay, so I can remove the bottom 2, and yeah i planned on maxing it out that far. Trying to think of ways to go farther. lol
Yeah, I would, but the deal i got these for I couldn't pass it up. nuh uh.fourLUG_hero wrote:
I chose to do both.
haha thanks. one more question. xDfourLUG_hero wrote:Oh snap my bad. They're 17/18.
What tire sizes are you running?
I will be running 18s with 245/55 rear and 235/35 front.
Why I want more sidewall in the rear, and I'll be drifting so I want a smaller sidewall in the fronts because i don't want to much oversteer.fourLUG_hero wrote:
Don't do that.
225/40 215/40.
I chose to do both.
<3pandapants wrote:
Priceless.
Very true its not, but thats not why I posted, I was just trying to give him a visual on the amount of side wall a 255/40/18 tire has vs. something that is a little more comonly seen on our cars,(225/45/xx) as he was conserned with the amount of side wall he would have, not if it would rub or not.hbpignosePA wrote:yes but your car isnt on the floor either....
im pretty sure 255/45 would rub with what he wants to do
<3<3ILoveMyRHS13 wrote:<3
I'm cutting the wheel well out as much as i can with 30mm over fenders with 18x9 -10 rims. 255 won't rub.. but i might run 245 on the safe side.kouki munster wrote:
And we would need to know alot more than just the tire size to be able to answer if it will rub.
It looks even better now that I've dropped that extra 1/2" out of the front that I gained from the sr swap. The funny thing is the rear coils are adjusted as high as they can safely go.hbpignosePA wrote:ah if your cutting them out you will be fine
i personally like your stance kouki
