fair enough. just askin. caz i know plenty of ppl and have scrapped many hondas with those installed. i do know what ya mean about not fitting the perch right because when i remove most of them they are in there kinda sideways and have to bang them out. never seen any bust tho, but i wouldnt doubt it. of course my hks coilover broke in half to so meh. lolOutToWinPAHC wrote:I used to have a EF., with ground control "coilovers" and Tokikos. The difference with those and these is this....
The GC brand actually fit the perches because they are made for them. They are not a universal item. They are also tested and tried true.
These are some universal items that wont fit the shocks right.
the ground control units are typically designed and engineered to fit a particular size shock tube, which is why they recommend use of a particular brand damper for a specific application. Those "sleeves" are "Engineered'' to "Fit" with universal applications, thus creating an acceptible amount of play(according to the manufacturer) to allow for multiple damper body sizes, the problem with this approach is that when that consumer gets these units they ( probably 8 times out of 10) dont fit exactly right on the damper body allowing the perch to shift to a stressed position and cause the sleeve to fail, or crack, i have seen it on many hondas that i have worked on at my previous job, simple fact of the matter is that they are inferior units and jeoparodize your safteyjeff420 wrote:ok, i always hear ppl say those things are unsafe but why? they are basically the same setup as the ground control ones
I always say just let it happen.If after the first 5 responses the OP is still dead set on installing these....then just let it happen. Darwin will take care of the rest eventually.Sometimes people just arent worth saving....i do feel for the SX but sacrifices have to be made.ZX88 wrote:natural selection always wins.
Hahah WIN!scuba_steve91 wrote:those "kyb coilovers" belong in thewhat is the biggest regret you've done to your 240thread.
skuurtin s13 wrote:
