coilovers
ibreakstuff
I want to convert my hardbody from bags to coilovers. I can't re-use the torsion bars because I have a 3" stainless ehaust running through the rear mount. Does any one have any advice?
Felipe
Car: abcdefghijklm nopqrstuvwxyz `1234567890-= ~!@#$%^&*()_+
why are you trashing the bags?
ibreakstuff
Because boost+bags don't mix.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
You can use coilovers right up through the UCA, but you'll be fabbing all the mounts. You'll need a coil tower welded to the frame, and you'll need to find coilovers the right length. Otherwise, what your wanting to do is absolutely possible, but you'll need some fab skills to pull it off.
