98240 wrote:How low did the kts drop your car
it was an accident to post in here i thought i was in hte suspension forumbut that forum was in a differnt browser i had open
Why has this somehow become the only thing that people are interested in coilovers? If you are tucking much tire on a 240, your car is overlowered. It will actually handle worse than if it was an inch higher. My car is dropped somewhere around 2" front and 1.75 rear. I could go a lot lower, but I don't want to. They go low enough. I could go another 1.5" lower front, and probably more in the rear if I wanted, but I won't, and you should't. You can also get new upper mounts for the fronts, which will let you lower them even more.
