Coilovers + Stock Height + Stock Geometry
Kon036
Car: 92' 240SX
I was wondering if there are any negative consequences to setting up my coilovers to stock height.
I want to keep the stock geometry, by keeping it a stock height, for handling purposes. My budget is a little to tight for extended ball joints, drop knuckles,
or anything like that and I'm not sure about slotting as a solution.
Besides not being able to have a "low stance" and some ridiculous wheel gap, is there anything I should be worried about?
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
All you really need are some rucas and whatever coil overs you have should have front camber plates. Other than that, just get an alignment. As for how it will handle at stock hight on coil overs it depends on how stiff you set up the spring.
