chmercer »
https://forums.nicoclub.com/chmercer-u5648.html
Mon Jan 23, 2006 10:44 pm
all that happens when you preload the spring is it shifts weight around. pre loading the spring higher up just to get a couple more threads of adjustment on the lower perch is counter productive, because the extra tension in the spring will just push the car back up.
yeah on the front you only "really" need 1 perch, the single perch can double as the spring perch and as the lock plate for the lower bracket.
the reason you dont droop the spring on the front shock is because of how the suspension is designed, you dont need to. since the bracket bolts to the spindle on the side rather than the bottom like on the rear, it has a hole in the bottom, so it can go up and down the shock freely.
in the rear, you have to droop the spring to get it lower because the bottom bracket is solid on the bottom, so there is a set maximum that you can thread it up the shock before it bottoms out.
ideally, drooping the spring isnt the "best" (it dosent really matter if you droop it 1-2cm or whatever) since what you are doing is reducing the shock travel, making your car more likley to hit the bumpstops on hard cornering. so if you do it too much you will bottom out the suspension and handling will suffer. basically just do it in moderation and you will be fine. just dont try to tuck lugnuts or anything haha.
also when adjusting i wouldnt reccomend doing it with the car on the ground. jack the car up, take the wheel off, adjust the plates etc. you can just leave them loose while you are adjusting, put the wheel back on with like 3 lugs, just do it hand tight since all you are doing is sitting the car back down to check it dosent have to be torqued and all that. once you get it where you want tighten down the lock plates and lug nuts and everything.
