Coilovers making noise when turning??
zeause
Ive installed a few sets of coilovers and rode in a bunch of cars with them and never heard them make this sound. Im lost. When i turn it sounds like the spring is binding up or kind of winding tighter. Theyre PBM and ive only had them on about a week. Thanks in advance.
Persona
Car: 97 Kouki
Sounds like you dont have your front coils adjusted and tightened properly as far as the collars and everything go upfront.
zeause
Should the collars be tighter against the spring? Like more pressure on the spring?
Persona
Car: 97 Kouki
zeause wrote:Should the collars be tighter against the spring? Like more pressure on the spring?
Everyone has their own preference on preload, too much of it though and they will ride like s***. I always just do about 5 turns once its touched the spring.
More importantly the collars should be torqued against each other as to not move.
zeause
oh thats what you meant, yeah ive got them torqued together. The fronts arent side specific are they? I didnt see any marking on them.
Persona
Car: 97 Kouki
No they arent, then do you have the part that attaches to your hub torqued against them as well?
zeause
Yeah i have them torqued to. Ill take the wheels off and check all the collars tomorrow though to make sure.
Dazzla
I always thought it was normal and just a 'coilover' thing.
Persona
Car: 97 Kouki
None of mine or anyone else I know of cars have ever done this.
Only thing left I can imagine is your spring is turning with your wheel and rubbing against the top of the coilover. Im sure you can fix this with a washer etc. of some sort.
Modified by Persona at 11:17 PM 4/10/2010
lucas240sx
Car: 340hp 03 wrx (daily)
90 240sx (weekend)
usually that happens when ur springs are turning when u turn.make sure there compressing and there not rubbing against your wheels or anything./
