Ceptos »
https://forums.nicoclub.com/ceptos-u840.html
Thu Mar 10, 2005 4:37 pm
yes, you dont want any preload on your spring. i guess the coilovers are already on your car, or i would tell you to hold them upside down so the spring is resting on the top perch, turn the lower perch so it just touches the spring bottom, then turn the lower spring perch one additional full turn. if they are already on your car, same idea, just cant hold them upside down =)
also, if your rear coils use helper springs, the helper spring itself should have either an ideal ending length, or the amount it should be compressed. for example, i think my helper springs are like 80mm tall, and i had to compress them 40mm or something like that. so if you have those you may want to look into that.
and for rusty bolts, along with the usual pb blaster, try a length of pipe around the end of the wrench to add leverage...ive sheered a few sockets that way tho so be careful =) good luck
oh, and i lowered my s14 about an 1.5" front and 1.25" rear, and i wouldnt want to drive it any lower than that, i avoid speed bumps at all cost. but i live on the east coast and roads are horrible, so not trying to discourage you.
