kouki munster »
https://forums.nicoclub.com/kouki-munster-u34314.html
Tue Sep 27, 2011 10:44 am
The upper pillow ball mount could cause that, stance had a bad run of those a few years back, and I was one of the lucky ones to get a set, but every time I hit a bump I had a loud knocking/clunk.
Jack up the car, grab the wheel on the corner that the noise is coming from, shake it up and down(simulate hitting a bump the best you can) and listen for the noise. You can also use a jack under the tire to accomplish the same thing.
