infinitedrift wrote:@debonair, I'm about to buy some coils tomorrow. You've have your coils for sometime time now. Do you like the spring rate you chose or would you recommend the 11k/8k? I'm not slamming but may want the option later. Have you had any issues with the bc coils since purchase?
I am happy with the spring rate I got. There is some stiffness bounce but this is unavoidable since the suspension travel has been significantly shortened. It can get uncomfortable on extreme washboard roads so I remember where those are and avoid them. I also subconsciously change lanes on the freeways to avoid know bumps and drops now.
IlyaKol wrote:Also, as I'm still going to be getting coilovers in the spring with the tax refund most likely, did you install the extenders? How did you 'cut them down' to fit flush?
infinitedrift wrote:@llya, the extenders are cut by a dremal tool or something similar of that type tool. The knob on the top had a set screw. Undo the set screw, take the knob off, cut extenders to length, put back knob, tighten set screw.
Correct, a Dremel cutoff wheel does the job best.
Remove the knob by loosening the set screw. Measure the length of the inner rod that is exposed at the top. Trim the outer sleeve (it just slips off once the knob is removed) to the necessary length. Then trim the inner rod making sure to leave the same length exposed at the top so you can remount the knob.
Those original pics with the extenders uncut were from another member. This is from my car a few days ago. The pic below is is also from my car and was posted in my wheels thread.
