jjisguilty »
https://forums.nicoclub.com/jjisguilty-u24141.html
Fri Mar 16, 2007 7:58 pm
I got my coilovers pre-assembled and since theyre not installed yet, i have time to play with them. With the unit fully extended, the spring can slide about 1-2mm back and forth on the lower spring perch. Will this be fine when I install them? Or should I raise the perch(increase pre-load). I'm new to coilovers btw.
