KAT S14 »
https://forums.nicoclub.com/kat-s14-u16982.html
Mon Jan 29, 2007 2:25 pm
I hate the KTS coilovers I have on my kouki. I had Megan on my zenki and loved them, wish I would have kept them.
As far as your problem. (Warning: Possible run-on sentence, I'm an engineer so expect poor grammar)
Loosen the nut with the green arrow so the nut with the red arrow can spin freely. Tighten the red arrowed nut so the spring is snug against the top, tightening this more will compress the spring, and increase your spring rate. i.e. K=P/U (K=spring rate, P=load, U=deflection) U is pretty much constant for a set of springs, by compressing the spring P is bigger and since P and K are directly proportional K gets bigger too. P gets bigger because you are adding an initial load (pre-load) + the load applied. K getting bigger means it rides more stiff. So..., once it is snug tighten the green nut to the red so it locks it in place. Adjust your height by loosening the blue nut and spin the whole shaft, and once you have it set tighten the blue nut to lock it in place. Make sure both sides are set the same so your sway bars don't hate you and you're done.
Search might have found this too.
