evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri Jul 25, 2008 8:26 am
the question should be prefaced by what you expect form a set of coil overs, if you just want the car lowered, the cheapest set you can find will do the trick, if you you care about performance then there are many options, but they will very on what kind fo performance you want, you can get coil overs with stock spring rates so the handling is more similar to stock, and of course spring rates are limitless deopending on your needs but you need a shock that can handle the rates you intend to run, if you're a racer then rebuildable shocks with if custom valving is important such as Koni, Carerra, ADS, etc
