merlinq2 »
https://forums.nicoclub.com/merlinq2-u171090.html
Wed Jun 05, 2013 7:25 am
That is great question- I have asked the infiniti repair shop and no one knows the answer to that. Most of the techs would need to go to the infntiti help line/center and ask those questions to see if there is anything listed.
I would suggest that a rattle in that area could be coming for a fatigued weld. When you replace the suspension the new more supple ride (compared to the older high mileage parts that were replaced) will in general soften up the ride cutting down on the over all frequency of the bumps. Therefore no rattle until the suspension settles etc.
I think I did find another posting on the net that talked about some bad welds on the earlier M's (while looking to buy one), most of the postings listed noises, creaks, rattles etc but never did post a solution.
Might want to look at the bushings in and around the sway bar. When those fail you get squeaks and booming noises from the rear end, sounds like the car is bottoming out.
