coilover mods questions
flex128
Car: 2006 Infiniti M35X
Hey guys i know this has probably been discussed before but i couldn't find the topic. but i wanted to know what coil overs are interchangeable like from G35 or G37 350z ones to go onto a M35X 2006 and if their are any performance parts i can use that are made for the other cars i know the engines are similar just not sure how similar they are can i use light weight pulleys for the G or Z on the M ? thanks for the replies
mr_luv
All X coil overs are interchangeable just need to consider the spring rate between the cars.
svard75
Car: 06 M35x
If it's a part that connects directly to the engine and does not require a body mount support then anything for the z350, g35 is interchangeable. When looking at replacing the pulleys make sure they aren't under drive. I had one before and my charging system was weak plus I had to use a belt from another car. All these headaches to recover a bit of parasitic loss.
Not sure about the coilovers. Just play it safe and go with either Megan racing, k-sport or D2.
