Coilover Install: Do it yourself?
Ceptos
Car: 95 240sx
heyas,
this seems like such a redundant question, but i am about to buy a set of coilovers, specifically JIC FLT-A2, and i asked around for install prices, one shop told me $200, another shop i went to didnt have a definite answer until they looked at the kit, but they said 200 sounded low.
so im thinking i might as well put them on myself, then drive it down the road for an alignment. is this something that i could do? ive heard that coilovers come with some type of instructions, what kind of tools are involved? do any of the nuts need to be torqued on? i guess all i need is someone who has done it before to give me the go ahead, any help is appreciated, thanks a lot =)
Exar-Kun
Car: 2005 350Z
check the FAQ, its got a link to a coilover install...-chet
Ceptos
Car: 95 240sx
broken link
Exar-Kun
Car: 2005 350Z
well crap. now I gotta find a new link. iut took jerome 2 hours to put them in by himself, but another 2 hours to adjust them.-chet
Stee Flo
if you get the flt-a2 then they will probably be preassembled with the pillowball mounts and all. It should be as simple as unbolting the 3 strut top bolts and the 2 bottom ones. As for adjusting, my teins had a recommended measurement in the instructions. Google is your friend. Here are some links that i found that might help you out. If you dont need to assemble your coilovers or transfer your stock strut tops, then those steps wont pertain to you. S13 Nissan 240SX Tein Coilover Install 1989-1994 240SX Tokico HTS shock install JIC Magic Coilover Install
BadMojo
Car: 2007 Mazdaspeed 3
Definitely put them on yourself. It should be much easier than installing a separate shock/lowering spring combo, and that's really not rocket science either.
You can take that extra $200 and put it towards some nice sway bars! :D
sr20power
Car: S14 Zenki
i agree wit badmojo....i put on tein HE's on my 95 240sx, it was relatively easy.....to install, pretty much straight forward: the front; 3 upper bolts,1 on the knuckle and brake clip... the back; 2 up top and 1 at the bottom...follow the torque specs from the fsm.....then comes the really work of adjusting height...i spent about a good hour getting it just right....
Ceptos
Car: 95 240sx
thanks for all of the help, so i wont need anything special to the get the old springs off? i am about to order a factory service manual before i get into this.
i emailed jic, they told me no english instructions, and that i should not install them myself, ehh.
thanks!
Stee Flo
if you dont need to use your stock upper mounts, then you dont need to take the old springs off. Im not sure how the flt-a2 is but my HE coilovers came preassembled. Since it came with pillowball mounts, i didnt need to take apart my old springs to get reuse the tops. Just take out the whole stock shock/spring assembly and put the coilovers on. Here is an instruction manual for the Tein HE. I know its not what you have, but its in english and might help on the install.
Tein HE manual
Ceptos
Car: 95 240sx
awesome, thanks a lot Stee Flo, i will definitly take a look at that manual too, thanks
