anybody with first hand experience please chime in. i dont know a lot about suspension and want to learn more about it. thanks
That doesn't even make any sense. They apply slight tension on the main spring to smoothen out the bump and rebound curves. That's it.motoman399 wrote:are you positive on that? a site i was looking on said its to get the piston on the strut at the optimal operating range when the car is really low.
quote from stance's web site.pandapants wrote:That doesn't even make any sense. They apply slight tension on the main spring to smoothen out the bump and rebound curves. That's it.motoman399 wrote:are you positive on that? a site i was looking on said its to get the piston on the strut at the optimal operating range when the car is really low.
This is what doesn't make sense. The coilovers are bottom mount adjustable so the pistons would be moving the same no matter the ride height. The addition of the helper spring enables the piston to compress and bound smoothly before compressing the actual main spring.motoman399 wrote:optimal operating range when the car is really low.
