pandapants wrote:I won't lie, I didn't understand anything you said except for the last sentence, which I think is still false. From experience, I have found that pre loading the springs on a coilover that's bottom mount adjustable the car would indeed be lower. It may handle worse, but is by far lower. Either my eyes are playing tricks on me, my tape measurer is wrong, my coilovers are broken, or I'm just dumb.
One thing that we both can agree on is the amount of force it takes to compress the spring and damper doesn't change, as the spring is linear. An 8kg spring will always need 8kg to compress 1mm. So why would compressing a spring via pre load be any different? Static, the damper would compress the same, and even though the spring is shorter from pre load, the spring will compress the same. So, the car would be lowered X mm from pre load and Y mm from static weight. Preloading a spring does essentially the same as using a shorter spring b/c the over all length of the springs from seat to seat is the same. No?
Drooping a spring does the same, but for a different reason. People droop springs (common in the rear coilover) because they have maxed out the adjustability range of the bottom mount. Since you can no longer raise the bottom mount due to the length of the damper, you droop or lower the spring. This essentially puts more weight on the damper shaft, and lowers the car until the spring is seated at the top.
This is what I believe is true with bottom mount adjustable coilovers.
What you're saying, or what I understood, is that preloading a spring X mm will essentially rebound the damper X mm therfore raising the car X mm. That, I don't believe is true when the suspension is static.
yeah probably a bad explination
and i will probably have to read your post a few times to fully realize the area in which were not quite seeing eye to eye on however from my own experience preloading the rear did raise the car lol so both are experiences are differing so there must be somethign amiss here
lets return to that lame picture i made for the convo
fyi i dont mind being wrong, just want to know why im wrong ya know...
so lets say you got 200kg going on the coilover in that corner of the car
you adding 200kg of preload too it OR no preload and lowering the cars weight on it(200kg) will compress the spring to the same exact length correct? we can agree on this because its a linear spring...yes?
ignoring the bottom purch what is the significant difference in those two set ups in relation to spring height, nothing right? were ignoring where its mounted to the car so as far as the spring is concerned they are exactly the same length
but
if we had the purch in the same spot non preloaded...then added preload, now whats the difference? you will notice that in order to preload it you must raise the bottom spring collar up...thread above the purch that is the green i was talking about and you will notice that if the purch does not move and you move the bottom collar up you will have alot more threads showing above the purch...yes? invision it in your mind.
would this not be EXACTLY the same ride height as running NO preload and lowering the bottom purch down by the same amount of threads that you would see above it if you preloaded it...
because no matter what you do the spring length will ALWAYS be the same length compressed (whether its 200kg of weight or 200kg of preload) and the only changing factor in height is the purch which when you preloaded it was more thread above the purch means its effectivly RAISING the car...does this make sense because i cant explain it better...
they make full length adjustable coilovers so that you can adjust preload and compensate for the change in hight by also raising the purch the same distance you preloaded the spring from the lower spring collar...this is what i understand to be the rational behind the height/preload adjustments being independent of eachother
now if you see a flaw in my rational please correct me so that i may understand the real truth behind the error in my thinking
