Gabes13 »
https://forums.nicoclub.com/gabes13-u92491.html
Fri Dec 25, 2009 6:54 am
Part Shop Max Coilovers.-Bought from psm in San Diego, Ca. -$1050 shipped to my door. -They come in 10k.F and 8k.R spring rates. -They make optional 6K springs that you can put in the rear and switch the 8k to the front. -I've heard mixed reviews about the quality in this set-up b/c of the shocks valving, but I have no personal experience with it. Sorry. -They're 10 way adjustable, with a noticeable difference in each setting. -1 being sporty and 10 being pretty brutally stiff. *Not inverted mono-tube like Stance or DMAX (all dampening knobs are on top instead of on the bottom (F) and top (R))-Moderate comfort can be achieved with a 60 series tire.-Camber is changed via camber plates on top of the coilovers. **They do not have slotted holes on the bottom mounts for more camber like DMAX or Function & Form.-For wheel clearance, they have about 6" of backspace on their lowest ride height setting.-I'm Sure you could squeeze more with moderate ride height and a shorter spring. -Their Bottom mounts are adjustable.-So no need to droop or raise the spring for ride height. -They go pretty low out of the box. -7" springs front and back.-Spring seats are like 62.5mm so they're not compatible with shorter springs from Swift or Tein. -PSM did offer a shorter spring that measured 5.3" a while ago.-They might be on special order know.-If interested though, Just send Dan a message asking about them.-He's a pretty cool guy.-Always replied with tons of info when I had a question.-Awesome customer service. -AA+++-If something does happen to go wrong with your shocks, they have replacement shocks in stock for $100. -Pretty darn good if you ask me.
*My interpretation:I was extremely satisfied with these coilovers when I got them. I bought these when my AGX shocks blew. The AGX were good shocks but I had the settings maxed out and still wanted some more adjustability (dampening and height wise) so I just opted for coilovers. It was between Stance or these. I picked these b/c I wanted to try this "new" company, even though I knew Stance was pretty reputable. I started off with a subtle 3/1 setting and I was really satisfied with the ride. I was expecting them to be a lot stiffer like people were complaining about. I kicked it up to 5/3 and it eliminated most of my body roll. Ride quality was still good, probably b/c of the stock 60 series tires I had. It's been a year since I first got them. I ride them at 10/8 now b/c I rub a lot with these monster truck tires at this ride height. Ride isn't very comfortable but taking turns have never felt better. DD or Track, these coilovers are versatile. And for a thousand bucks, you really cant complain.
-Gabe, one Satisfied customer.
circa 12/09
12/09Both collars removed
