I'll get alignment tommor then see what happen. No I never had coilover in past this is my first one one my maxima. I know they are bumpy but y do they do that?pandapants wrote:Try getting an alignment first. Have you ever had coilovers before? They are pretty bumpy
I'm on 20" rim 245/35/20. I been playing with my dampering n I think mine is set to 15 or 16 from 0. Manual book said hard is 0 n soft is 30 so if I want stock travel I should set it to 8 dampering. Should I set it to 8 n will I get better if I go with 17" stock wheel? I was thinking to buy strut tower bar is said it'll reduce bumpy n other thing which I can't remeber. So if I get alignment then after that my car won't boucne correct? Check out my vid of bc racing coilover.pandapants wrote:Coilovers have higher spring rates than stock, so the ride is kinda bumpy. If you have stock wheels and tires it will contradict the new suspension and feel kinda, "bouncy". Try playing with the dampening knobs. Ride on some different roads and find a happy median. Camber plates are used to correct the camber of your front wheels. Since coilovers lower your car a substantial amount, the camber and other suspension geometry changes. If the tech doesn't know how to adjust you suspension, you should probably look for another alignment shopEnjoy your new coilovers.
There is a difference between stiff a** shocks and a shock that bounces after hitting a bump. The little bit off bouncing that remains will stay there. The quality of the shock/spring determines this. If the car bounces or oscillates excessively then the valving is off. There are two parts of valving. Compression and rebound. Compression controls how fast the shock will compress and rebound how fast it "springs back". If the valving isn't matched to the spring you can get a multitude of characteristics such as bouncing. This is very characteristic of lower end brands ( Such as BC, Stance, Megan etc. ). Spring rate isn't everything in determining ride quality.Rohanmax14 wrote:Okay guys finailly I got alignemnt that day when putting new tires flaken-452 on. I got 4 wheel alignment n balance tires. Will I think shop did not mess with camber plate cuz Im not super low like other car I have seen. Anyway my coilover still boucne on the hwy little not like jumping boucning. Lol
check out vids on bottom that the best I could made by iPhone vids.
http://www.youtube.com/watch?v=FddCKG0kkqA
LugNut18 wrote:There is a difference between stiff a** shocks and a shock that bounces after hitting a bump. The little bit off bouncing that remains will stay there. The quality of the shock/spring determines this. If the car bounces or oscillates excessively then the valving is off. There are two parts of valving. Compression and rebound. Compression controls how fast the shock will compress and rebound how fast it "springs back". If the valving isn't matched to the spring you can get a multitude of characteristics such as bouncing. This is very characteristic of lower end brands ( Such as BC, Stance, Megan etc. ). Spring rate isn't everything in determining ride quality.Rohanmax14 wrote:Okay guys finailly I got alignemnt that day when putting new tires flaken-452 on. I got 4 wheel alignment n balance tires. Will I think shop did not mess with camber plate cuz Im not super low like other car I have seen. Anyway my coilover still boucne on the hwy little not like jumping boucning. Lol
It's all garbage compared to the good stuff.poshatch wrote: cause i mean last time i checked stance GR+ Pros were really really good coilovers
and i think megan tracks are pretty good..even the streets arnt that bad
^ Thispandapants wrote:It's all garbage compared to the good stuff.
LugNut18 wrote:^ Thispandapants wrote:It's all garbage compared to the good stuff.
Stance is pretty good for the price. But when compared to Koni, KW etc. it's not. Unless you can afford ~$1600+ shocks and springs, you're going to have to sacrifice some handling characteristics and ride quality.
Unless you compete in motorsports, it doesn't matter. If I had a car I just farted around in and wanted coilovers, I'd buy whatever crap was available for cheap.poshatch wrote:
im sitting here thinking that stance GR+ pros were pretty good and you just rocked my worlds saying they are garbage
i dont even what to know what my tein HE's are (probably s*** compared to garbage)
weird...
If you're looking to autox seriously, you're going to have to jack your rates up heavily. I run 800 lbs in front and 600 lbs in the rear.poshatch wrote:i go to the track and drift at least once a month, looking to get into more auto cross but i know my set up isnt correct for that sort of thing and i got to find a way/ time to change set ups depending on where i go
looking to comp. pretty soon actually so ill see how s*** my s*** s*** is s***
