Meaning "no seat"?ChunkiDori wrote:those shock assemblies require you to take the preload off the front assemblies to lower the car...
hmm...on my civic I had the sleeve type coilovers, so excuse my ignorance with real coilovers. Ok, so just like I thought...upper spring perch: yes.Dori Dori wrote:Woah, woah, woah...DO NOT mount the coilovers on your car without using the upper spring perch. The spring DOES NOT rest on the strut mount.
The thing Im not understanding is how come the spring sits so far down from the top of spindle. And how Im supposed to start 1.2" from the bottom. With the sleeve types, I started from the top of the spindle and the lower you went, the lower it dropped.Dori Dori wrote:Even with coilover sleeves an upper spring perch is provided.
You go down to make the car lower.
I never understood why non-rally application coilovers allowed for higher than stock height settings either. It's just how they make them I guess.Neejay wrote:
With these, you're starting from the bottom at 1.2", which seems to mean that you can only lower it that much. Its quoted "approx. lowering as -1.81"...so I guess that means its lowered that much from the beginning, and "height adjust range being -1.02 -> -2.54"
So does that mean that Im starting lowered at 1.81? And that extra 1.2" left to go down just means I can lower it some more?
Like I said, whats throwing me is how low the spring sits past the spindle in the first place.
