Coil system
Florida240sx
At what levels of power/psi did you have to upgrade your spark system? Currently having a bit of trouble taking off time to time, and going wot. Once I'm moving it's fine.*Could be timing*From what I've read we are good up to around 350hp 15ish psi. Varies with your setup, like the fuel you are using and turbo size. Is this correct?
dsylvia
Car: 93 hatch
i figure if your taking the time and money to turbocharge your car, you might as well upgrade the ignition. after all it only costs a few hundred for a MSD 6AL and coil and some wires.
thats the system im using.
Florida240sx
I am goign to upgrade. But was wondering if this was the problem. Doens't make sense on how it does it coming out of first but is fine at WOT under 12psi....Which one do I need to get to set-up a 2 step???
MarkEmark
Car: fully-built '95 240sx KA-T
Florida240sx wrote:At what levels of power/psi did you have to upgrade your spark system? Currently having a bit of trouble taking off time to time, and going wot. Once I'm moving it's fine.*Could be timing*From what I've read we are good up to around 350hp 15ish psi. Varies with your setup, like the fuel you are using and turbo size. Is this correct?
I have no problem with my system at 16.5 psi out of a GT32...all that's upgraded is aurora 8 mm plug wires, iridium ix plugs gapped to .028, JWT ecu controlling timing. I'm probably at the limit though.
