Use these insteadCostee wrote:Hi guys, I'm thinking of increasing the ground clearance of my 2006 M45 Sport by slight margins. What coil spring height/dimensions would serve my purpose? What are the dimensions/height (front and rear) of the stock springs?
Thanks.
Interesting link. I've found a way out by elevating the rear spring seats with rubber spacers. I think I've achieved some 0.7inch increase. I'm pleased with the effect of the improvisation. Probably my springs are beginning to weaken, though this is imperceptible for now. I'll consider replacing them next time.msvara wrote:Use these insteadCostee wrote:Hi guys, I'm thinking of increasing the ground clearance of my 2006 M45 Sport by slight margins. What coil spring height/dimensions would serve my purpose? What are the dimensions/height (front and rear) of the stock springs?
Thanks.
http://www.oreillyauto.com/site/c/detai ... &ppt=C0361
Ok. Thanks.elwesso wrote:Remember any time you change the ride height you should get an alignment.
Oh, how nice of you. But I'm too far away from you to be helpedmsvara wrote:Those work to keep the sag out of the springs but the metal adjustable units can really give you a boost. Don't know if you've ever seen the sag maximas suffered from 03+? But these are great helpers. Only issue is they have to be tight with the cars load off of the springs otherwise they may fall out while driving.
Is it the rear springs that you need to replace or front? I still have my oem rears if you want them free plus shipping. Pm me
