fueler »
https://forums.nicoclub.com/fueler-u54519.html
Tue Aug 28, 2007 8:33 am
How did one coil spring go bad?? Have you checked to ensure that the spring is properly seated in its perch on the strut? Just replacing one spring would probably be fine, but if it were my car, i'd at least replace both fronts, and do the struts if they haven't been replaced (it's all going to be taken apart anyways)
