Why?one ton garage wrote:If anything, you'll usually want to cut springs from the top down actually...
Yes exactly one coil off the bottom, and the rears will be the same although I haven't investigated the differences front and rear.Q_SHIP wrote:
And this was the bottome coil correct? Is this what you plan for the rears as well?
Could you please explain? Waiting to learn here.one ton garage wrote:If anything, you'll usually want to cut springs from the top down actually...
Great explenation, thank you.one ton garage wrote:If you take a look at your assembled struts (and those on most cars), you'll notice that the top coils are usually already bound together...that is they're already in a fully compressed state, so in most cases, removing them won't really make a drastic change in ride quality and spring rate, while still lowering the car. Also, even when you cut past those "dead coils," the affect on ride quality isn't as pronounced, as the tighter top coils of most profressively-wound springs don't come into play until the softer part of the spring is already compressed.. i.e. under very hard driving/spring compression. Thus, for the majority of your driving where you're just moseying along, those top coils won't really matter that much
I'll be selling my 2" drop Teins very soon if you are intrested.StrangeLove wrote:I'm interested as well. 2" drop on cut springs and new struts...
Let me ask you this, how many coils should be cut to get around an inch?
Turns out that the tops of a Y33 springs are not fully compressed. However, on cars where the coils are compressed the previous explanation of where to cut makes alot of sense.Q_SHIP wrote:
See attached picture of a stock UNCUT spring. One bottom coil equals about 1" drop.Q_SHIP wrote:
I think the bottom coil is the one to cut. If you'll notice the picture of the stock spring you'll see that the top coil is very flat and when installed rests in a rubber spring seat. If the top coil is cut then the spring will sit unevenly in the rubber seat and I'm confident will tear through it eventually.Q_SHIP wrote:Guess im just gonna wing it. Im jus confused on cutting the top or bottom considering there are views on both.
Yes, I used a metal cutting blade in my skil saw. I also flattened the cut end slightly with my grinder so that the spring would sit flatter in the perch.captainluigi wrote:can you cut the spring with a cut offf wheel? if so cut it flat as possibe and touch up with a die grinder.
Hey, not speaking for bullitandy but this thread is more than 2-YEARS-OLD. Don't get all butthurt if you don't get a prompt response.davistation wrote:Hey bullitandy I live in Atlanta area and need my stock springs cut on my 97 Q can you help me out?
