Coil problem
DammitBobby
Car: S13 91 KA24DET
I have a SS Blaster coil that has a special connector that you have to swap out with your distributer wire. I was wondering what would be a better coil that will use a standard coil plug since I bought new NGK wires and has brackets to bolt to the fender.
nissanfanatic
Car: 1992 Nissan 240sx SE
Swapping that plug is super easy.... Just try it. Worst case scenario, you use the old distributor wire which is prolly fine as is. Its just a crimp..
DammitBobby
Car: S13 91 KA24DET
Well I went to a speed shop and they had a kit for the coil wire. It was only 12 bucks so I went the easy route.
