coil packs
epickakashi
Car: 1993 Nissan 300ZX 2+2 Twin Turbo
hey how do i check if the coil packs in my car still work?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
measure impeadance, if one reds higher or lower or open you have a bad one, also if you have a misfire you can move the questionable coil to a differetn coil and determine if the miss follows it
SpeedFreak_Josh
Car: 1990 300zx TT
BTW what are the specs on impeadance??I need to do that check myself. Thanks
Zwicked
Car: 1990 300 ZX tt, 1990 240SX
Primary is 0.7 ohms, secondary is 8.0 Kohms. Find it in the Factory Service Manual EF & EC 190
http://300zx-twinturbo.com/cgi-bin/manual.cgi
You can also remove the coil pack but leave it plugged in, plug in a spark plug, ground the outer part of the plug to engine block and turn the engine over to see if it fires, just don't shock yourself. That will at least tell you if it's working
