SoundEfx »
https://forums.nicoclub.com/soundefx-u242936.html
Fri Jan 16, 2015 6:58 pm
If it is your coil pack, you should be getting a misfire code for a specific cylinder.
After you have that info, change the coil pack from the bad cylinder to one that is known to be good, drive the car around for a while and check your code again.
IF the code moved to the same cylinder as the coil pack, then you know that specific coil pack is bad.
IF it stays on the same cylinder, then you know that it has something to do with the wiring or something else pertaining to that specific cylinder.
Start with that and let us know what you came up with.
