Postby
Nicksemianiw »
https://forums.nicoclub.com/nicksemianiw-u24891.htmlTue Oct 25, 2005 2:36 am
So yea 2 of my coil pack bolts snaped while puting them back on. Can i run the car like this? And when i get my head done will it cost alot more to fix?
Postby
9240sx »
https://forums.nicoclub.com/9240sx-u11838.htmlTue Oct 25, 2005 7:01 am
I do that all the time,You sould be apply to get it out with some vise's grips.But the last time i did it i had to take the valve cover to a machine shop to have them drill it out,But i think its because i broke the drill bit in there trying to fix it But ya those little 10mm coil pack bolts brake very very easy,They sould be torqued to 4-7lbs.GOOD LUCK i hope you get it out.
Postby
Hijacker »
https://forums.nicoclub.com/hijacker-u9394.htmlTue Oct 25, 2005 10:11 am
you can run without them, but i wouldn't suggest just leaving it that way. the coil pack can shake loose and pull off the plug just enough to weaken the spark and cause some funny mis-firing issues.
Postby
PDX_S14 »
https://forums.nicoclub.com/pdx-s14-u32808.htmlTue Oct 25, 2005 12:07 pm
nah... the coil packs is in there pretty deep it wont shake off that easy. on top of that you can put on the center cover on thats for sure it wont come out.
Postby
Hijacker »
https://forums.nicoclub.com/hijacker-u9394.htmlTue Oct 25, 2005 1:26 pm
ILikeMy240sx wrote:Yeah you can run it like that. I had to run mine like that because the powder coat on my valve cover kindda made that bolt hole smaller...
