coil pack 1990 Q45
breda43
Car: Infinity Q45
WHERE IS THE COIL PACK LOCATED AND WHEN DO YOU CHANGE OUT?MY Q45 HAS 238,000 MILES ON MOTOR AND TRANSMISSION.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
On each plug and NO NEED TO SHOUT!
We can read pretty well, thanks.
PopPop
Car: 1990-91 infiniti Q45's, S13 Coupe, 3rd GEN. Max
breda43 wrote:WHERE IS THE COIL PACK LOCATED AND WHEN DO YOU CHANGE OUT?MY Q45 HAS 238,000 MILES ON MOTOR AND TRANSMISSION.
U are working with a Infiniti Q45 VH45DE! Your car has a coil pack for each cylinder so U have eight of them. If it's not broken leave it alone. Four of them sit on top of each head!
PopPop
maxnix wrote:On each plug and NO NEED TO SHOUT!
Take it easy on your fellow members Brian!
breda43
Car: Infinity Q45
Thank for the support and info
Q45tech
The coils don't fail on 90 Q the screw on extension may arc if the plug well is not kept clean and free of oil [reseal of valve covers] or using non oem spark plugs changed at 4 years and or 60,000 miles.
breda43
Car: Infinity Q45
I'll keep that in mind.Thanks
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
PopPop wrote: Take it easy on your fellow members Brian!
Sensitive eyes, you know.
