chmercer »
https://forums.nicoclub.com/chmercer-u5648.html
Mon Oct 11, 2004 5:18 am
well assuming you have a standard set of coilovers, there is absolutley no way you could put them in backwards because the top mounts have different bolt patterns. even if you had no idea what you were doing, just about the only thing that you could screw up is you *might* put them in in such a way that the camber plates would be sideways.
