It depends on the size of your tires and rims. If you have a larger rim, say a 19 or 20 and you keep the same width of sidewall, you will need less lowering to fill in the gap between the body or wheel well and the tire/rim. Either way, I would not lower the car more than one inch as has been said above, unless you also plan to add aftermarket toe/camber adjustment equipment. If you lower the Z more than 1 inch, w/o the latter, then your alignment will be screwed and you will go thru your tires very quickly. If budget is a concern, go 1 in drop springs and you're done. If you can afford more, then go coilovers (stay at 1 inch), your preferred rim/tire combo, then go camber/toe adjustment arms in that order. Once you are at the last stage, you can go as low as your setup will allow. Of course, now you will need that 4 wheel alignment as well. Anything over an inch drop will require re-alignment. Also, if you have aftermarket rear valances or bumpers and front lips, etc. this will also effect how low the car can go without scraping. Do you live where there are a lot of speedbumps, steep driveways and hills? If so, then be careful. If you have the TEIN coilovers with the electronic controllers, then you can change the ride height on the fly. So, the answer really depends on how much money do you have to spend and what mods do you plan on in the future. Just MHO.flyguy2618 wrote:Ok thats great i get what the difference is and all the bennefits of each one thanks alot for the info that helped alot because i didnt know anything.
My last question if anyone really knows(and im sure it changes depending on the person) But how low is low enough to give it a more agressive arodynamic look while still not being so low that i scrape on anything, or have a problem with bumps and things on the road?
