coil overs or lowering springs
xero1
Car: 08 Altima Coupe
i am planning on getting a 96 240, i want to setup up drifting suspension on a buget should i get lowering springs or coil overs, i will be using 4 kyp agx adjustable shocks/struts.
navysnail
if by coilovers you mean adjustable springs, then go with normal springs
if by coilovers you mean tein or jic or somthing along those lines, go with those they are far superior
Neejay
240kid wrote:if by coilovers you mean adjustable springs, then go with normal springs
Yeah, basically what he said. If you mean the "sleeve" type coilovers (like skunk2 or ground control) rather than the "true" type coilovers (jic, tein, etc.), do like 240kid said...
Dont mean to sound like an echo
silkk
Car: 94 B13
89 S13
07 S2000
jic all the way!
Structure240sx
if your really on a budget than stay stock. you can drift on stock suspension, dont listen to the magazines
if your going to upgrade soemthing, i suggest to save and get a quality brand name item. you will end up upgrading to it later like me wasting money
