Coil overs: How low can some go?
silviaziz
Car: 1992 Nissan 240sx hatch-back
I am really just interested in just 2 brands, Stance and Endura-tech. I will be putting on a set of rota off-road grids with 225/50/16 size tires. Will the Endura-techs be able to go low enough to eliminate any fender gap (on their website, it states that these coil overs have a 2.5 inch drop), or will I need to go with Stance GR+ Pros. Also, how low can the Stance set go?
And as for quality, which is better? I know that Endura-Tech is a sister company of the largest manufacturer of OEM springs in the world, so this leads me to believe that they will have the highest quality.
silviaziz
Oops, I didn't realize I wrote "just" twice in the opening line.
silviaziz
And before anyone says anything, yes I have searched.
ca18tt1978
Car: 1991 240sx/180sx ca18det swap
You replied back 2 times in 3 minutes . Theres a thing called EDIT you could of just edited out the second JUST .
Also Search there has to be like a million coilover questions about quality and ride hight and so on .
adrianfromthecastle
as far as ride height goes, Stances go pretty low.
I haven't seen how low Enduratechs go ( I don't even know anyone with them).
how low are you planning on going?
Quote »And as for quality, which is better? I know that Endura-Tech is a sister company of the largest manufacturer of OEM springs in the world, so this leads me to believe that they will have the highest quality.[/quote]a pair of 10k springs are 10k springs, no matter what company makes them. They're all the same in quality.Damper quality is the characteristic you should look out for.
S14toRPS13
The Stance's will be able to lower your car to the ground and then some. Just FYI, if you're planning to go with 225's and you want to slam your car, you won't be able to pull it off without a roll and a pull.
silviaziz
CA18tt, You have to forgive me when it comes to forums. I tried to edit and I received a response saying that I was not entitled to do so, but that doesn't really matter.
Thanks to the other 2 that replied, I know that you, RPS13, run Stance and I appreciate the info regarding tire size. You run 205/50/16 I'm assuming to avoid this problem. Does stretching the tire effect safety, handling or grip?
Thanks again
PHeller
Car: 1998 Ford ZX2 (wrecked) now 1989 Coupe
Going too low messes up a few "correct" handling aspects of the car, aka, they aren't designed to work at a 3" drop.
Of course stretching a tire will provide less grip than a correct fitting tire on the same wheel. Running 8" wide wheels 205's won't grip as much as 225's.
Plus then there is the whole issue with avoiding road imperfections and such.
I hate to sound like one of the "anti-coilover" Nazi's, but lower is not always better. Usually quality compression dampening, quality valving, and well selected spring rates provide the best street setup.
silviaziz
Thanks for the reply PHeller. Would you recommend the endura-tech coils then? Do you have any experience with them or know anyone here that does (I have read the few reviews here and the one from Modified Mag).
lay-N-low S13
Car: 1990 Nissan 240sx
how about some pics of slammed 240s to help this guy out
MastaYu
Car: 92 Nissan 240SX SE HB
stance are very nice! Pheller is right about going to low but their are adjustable control arms, tie rods, etc to correct the suspension geometry
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Endura Tech has been a sponsor here a long time and they have an awesome selection of spring rates to choose from. I would shoot them an email and see what they suggest. They cost a little more, but their design is nice, and they are customer service friendly.
Check their page and see the articles / technical info
impact240sx
Car: 1993 240sx Sr20det Gt2871R 2003 350z 1991 240sx Sr20det 2004 Land Rover DISCO
Honestly I LOOOOVE my stances but they don't go as low as I wish. Here is a picture of the lowest the front can possibly go. Oh and it doesn't get lower when I drop in the motor. The coilovers are so low in the front that I had to cut the bump stops off og my control arms because they were hitting when I turned the wheel.
musashin
Car: 1993 S13 hatch
AZHitman had Endura-Techs on his vert before the air suspension went on, and they seem to have gone plenty low to me.
simmode1
Car: Red '95 S14
musashin wrote:AZHitman had Endura-Techs on his vert before the air suspension went on, and they seem to have gone plenty low to me.
^^^ Yeah, but he has HUGE frikken wheels to fill the wells...
S14toRPS13
silviaziz wrote:Thanks to the other 2 that replied, I know that you, RPS13, run Stance and I appreciate the info regarding tire size. You run 205/50/16 I'm assuming to avoid this problem. Does stretching the tire effect safety, handling or grip?
Thanks again
205's on an 8 in wide wheel is barely a stretch. IMO, it also looks better than the bulky look of the 225's on the Rota Grids too.
I also don't think there is going to be a noticeable difference between 205's and 225's in regards to traction anyways. Now before I get flamed for saying this let me explain. I have a friend with a nearly identical set up like mine. Stance coilovers and SR putting out about 300 hp. He's running 255's in the rear though and he still doesn't get traction from a stand still. It's not so much the tire size on the 240's, but the fact that most of us like to slam our cars with stiff coilovers. That's why it's hard to get good traction from a stand still.
Gabes13
Car: rb20det s13
If you want low, kts ultra lows are the lowest ive seen.
Of the two mentioned though, I personally would go with stance just bc Im not diggin endura tech's spring rates.
It went plenty low on the 17's too, though. I really like the Endura-Techs.
Couple pro drifters have driven my car hard on the track and reported they were pleased with the handling as well.
