Coil over springs.......
Drinkin610
Car: '92 240sx
Ok i am following the custom install instuctions for this install. I really understand just about everything but..... The springs r 2 different sizes, ones longer than the other. Which one goes where? One is longer than the other... Help everything is at a standstill...
Thank YouRoger
crzycav86
Car: 93 Nissan 240SX KAT
You're installing a set of lowering springs?
It should be pretty self-explanatory, because the front and rear springs cannot be swapped, and they look nothing alike.
The front springs, compared to the rear springs are shorter and wider(diameter-wise).
But maybe I didn't understand your problem very well. If so, explain further.
BuudWeizErr
sounds like he bought those crappy *** ebay 'coilovers' which do nothing other than allow for adjustable lowering.
LAME.
