Amadauss1 wrote:GerryO, could not help seeing a post you had for suggestions on doing some other things to the car. Don't want my daughter breaking down so thought I might tackle the EGR and PVC valve. Also read about cleaning the manifold and the junk that came out. Obviously to start this project a lot of things to disconnect. Any place on the site showing detail of this type of project? Thanks
The J30 can be a strange and challenging beast. Gas (premium fuel) mileage isn't great, parts (some are common with the Nissan Z32/300ZX engine) are a bit expensive, it has an interference engine (timing belt breaks = bent valves/piston damage) and it's also rear wheel drive. It has quite a number of electrical quirks (radio, speaker amplifiers, head lights, interior lights, door locks, windows, sun roof), but yours is a '97, which is good for a number of reasons. I replaced a leaking water pump at approximately 170K miles, along with the timing belt, oil seals, etc and then an injector failed couple of thousand miles later, followed closely by an O2 sensor. Overheating may cause damage to the knock sensor, which affects engine timing.
Replacing the EGR valve is a bear, but PCV valves are cheap. Make sure your daughter knows how to start a seemingly flooded engine.
These are among my two favorite links.
http://home.swipnet.se/e-solutions/IdleTech.html
http://home.swipnet.se/e-solutions/IdleTech2.html
My daughter drove a '98 Honda Civic for 10 years and it never failed her. I'm waiting for the transmission to fail on my '93. Wish I could be more encouraging and thank you for the update on removing coil packs. Best of luck!
