TheOne wrote:BAS = boost a spark, device kennebell makes to raise the voltage to the coil and thus more ignition power.
there's a couple of writeups on the .org site, you'll have to search as i can't post that link, but essentially since the aem ems has outputs that it doesn't need(like egr, and other stock sensors), you can use those pins to run other coils(up to 5), you just leave the stock distributor in, rewire coils 1-4(1 being the wire that goes to the stock coil, the other 3 can be seen on aem's wiring manual), there's a wizard you may have to download and some settings to change on the ems for when you change to cop though.
Wow, that's quite a little write up. That makes a lot of sense if I ever do plan on going with a COP setup.
WDRacing wrote:I'd never go with a coil-on-plug setup unless I was revving the piss out of the motor, like 9k+. Or if you're having spark issues, like blow out. But there are a few options I'd use before I'd go through the hassle of COP.WD
That's true, it's really not worth it unless you want the absolute best ignition system possible, or you need it because of high boost blow out or high horsepower.
